Coil bracket mount? Looking for a better idea
3.2K views 14 replies 12 participants last post by  Doug Meldrum
#1 ·
Before I break out my jigsaw, metal break, and aluminum..........
I thought I'd check with you guys for a better idea.
What are you guys using to mount your EFI / OEM Square Ignition Coil?
I looked at the original bracket, but it's pretty specific to the original location and would not mount flat without modifying.
Does anyone sell a simple mount?
looking for ideas. Thanks
#2 ·
temp location first with in coil wire length
or try that chunk of AL rectangular stock i gave you for a stand-off bracket
#3 ·
Direct
I screwed mine straight on to the square tube around the hood opening. Looks clean, works fine. No special brackets.
#4 ·
Not a great shot of it, but if you look on the other side of the AC compressor, you can see the square tube where mine is mounted.
I can get a better picture if you need it.
#5 ·
#14 ·
Forte's EFI coil bracket
Hi,
The coil bracket I make mounts the coil just in front of the distributor. It then uses a 12 inch coil wire. Nice & clean and a short wire which is a real benefit.
#6 ·
Whitby Motorcars - Coil mounting bracket
Whitby Motorcars sells a nice aluminum Coil bracket that I have used. Good quality.
#7 ·
Mallory sells an EFI coil that comes with it's own mounting bracket. Mine is mounted as per this pic:
Sean
#8 ·
canuck1, do you happen to have the part number?
The Mallory that I looked at on Summit, said no bracket included.
#9 ·
#11 ·
If you want to keep things clean, mount it to one of the heads. These type of coils aren't subject to vibration issues and a bit of standoff with a plate makes heat a non-issue.
Regards,
#12 ·
Another moment of weakness (dammit, you guys are always waving the cool parts in front of me and I'm biting every time! :001_smile:)
That thing will look good on my DS F-Panel! A couple riv-nuts and buttonhead stainless steel bolts and I'm as good as done! :001_tongue:
#15 ·
I threw away the mounting bracket off my stock coil, cut a hole in a piece of aluminum, polished it and mounted the coil and the brake reservoirs to it. I then mounted the whole thing to the 3/4 tube. It's not a great picture but you can see it.
